Junk Collector
⭐Supporting Member
Truck of Month
This, except use a pry bar to move the wheel straight up and down. It's easier to find ball joint play that way. Rocking it by hand can throw bearing or tie rod play into what you feel and give a false positive.
Usually I can see a bad ball joint just by looking at how the knuckle moves relative to the beam. Ball joint or wheel bearing play are both pretty easy to see and distinguish from each other. Any more than 1/32" play in ball joints equals worn out anyway
