Ball joints
Just take the axle shaft or tie rod end in to the parts store and let them figure it out.
Lol easy to do when u have more than one vehicle to drive. This is my only rig now. Guess I can measure it myself.
you've got a d35 front end and that's all the parts store needs to know. no size problem unless the clerk is an idiot. :icon_confused:
LOL, I was going to say something similar. Doesn't seem like too many of the name brand stores have employees that know a thing of what they're selling.
I did some checking with O'Reilly about your u-joints. I guess there are different u-joints depending on gear ratio. According to them you need:
With 3.45 or 4.10 gears:
Precision brand - part #466 (greasable)
Precision brand - part #436 (non greasable)
With 3.27, 3.55 or 3.73 gears:
Precision brand - part #377 (greasable)
Precision brand - part #371 (non greasable)
Hope that clears things up for you. I don't know what AutoZone goes by. NAPA also sells Precision u-joints and I have had good luck with them, so that is probably what I would get. I was not aware that gear ratio mattered; it seems kind of bizarre but that's Ford for ya.
BTW, about your tie rod ends - there are two listed - one left, one right in any brand - you need one of each, they ARE different, and have different size shank and thread.
Now to find my gear ratio lol. It's a 5 speed 4wd, don't know if that helps.
Guess I will just have to do some measuring later on with the tie rod ends.
The metal tag on either axle will tell you. Bottom line should begin with something like "4 10" or "3L55" - the L on a rear axle tag denotes a limited slip and the other numbers are your gear ratio. The first number might be hidden under a bolt so you may have to remove said bolt to see it.
Don't bother measuring the tie rod ends, just buy one of each. You need both.
Ok, I will check the tags. The metal tag that I pulled off the rear axle housing when I did the gasket is just about unreadable lol. Will see if I can read it tho.
