Ball joint question
amarillo06
hey all, buyin new lower ball joints for my torsion bar suspension. Plannin to get the press tool.
Any suggestions or tips to help this go as smoothly as possible? I thank you in advance
Support the truck by the lower control arm, remove the knuckle/caliper/caliper brackets. Press out and press in a new lower balljoint and replace the upper control arms for the supper balljoints.
I would put in caster/camber eccentrics while you have it apart and then take it to have it aligned when done.
Good luck!
