bag brackets for i beamed ranger
To me they look weld on, but maybe someone else can confirm it.
Robert
Pretty much air ride company out there sells those style brackets and they suck. You can lay out on about a 17" wheel with low pro tires and run a small 2500lb bag and have lots of rubbing issues. That price on those brackets is also really high. These brackets I sell will fit a 2600lb bag and allow you to lay a bigger wheel with better suspension geometry. However make sure you have DJM drop beams and a set of radius arm relocators installed first to set the bag up for the propper suspension geometry https://www.illusivefabrications.co...file=product_info&cPath=29_36&products_id=321 a bigger bag means less pressure to lift and more bag stroke to use. Pretty much all Ibeam ranger bar brackets on the market are weld on. You will also need to notch for your tie rods. If you have any other questions or anything else I can help you with please feel free to email me brian@illusivefabrications.com I specialize in rangers and sponsor TRS.
