badge removal help!
blk&blu03
chico
yeah i have an 03 fx4 lv II and i want to remove all the badges i was wondering if anyone knew if my year has those little pin holes behind the ranger badge on the quarter panels any help would be much appreciated im new to trs but i love this site and have just subscribe because it has been extremly helpful in everything ranger related thanks TRS your awsome
well WELCOME TO TRS! you should just be able to put a door panel popper or flat head under thm and popem out the "RANGER" on the side may have adhesive foam under it which is a pita to get it all off with out hurting the paint. heat guns work good on those
All ranger emblems have alignment pins behind them and there are 3 holes in the fender
(o O o) yes its true three hole in back. just use a hot air gun and remove with your finger. it has a little foam at the back I think ..make like Clifford said that as
thanks guys im givin it a shot on sunday when im off of work i think im going to try dental floss or fishin line(and heat gun with the finger trick) well see how it goes ill just use a screw driver and a piece of wood for a block to pry the emblem off once again thank glad i signed up already
