Bad Sounds
Eric Kropp
Prunedale CA
So my faithful 1983 Ranger 2.8, 5 speed 4X4 of 20 years is making some sounds that are very concerning. When decelerating it momentarily "snaps" out of gear and it will lurch forward like it hits neutral for a second then catch. Hasn't done it accelerating. Then the latest thing it did was: when I shifted down from fourth to third, as I let the clutch out it ground gears just like if I had tried to shift with out a clutch. I pushed the clutch in and let it out again and it engaged. I'm thinking sincros (spelling)
Eric<><:icon_confused:
More bad sounds.
So I need you guys to think on this one. It now has ground in between shifts 3-4 times and has momentarily jumped out of gear in reverse under load and first when decelerating. But check this out, I put it in low range and it won't do any of the bad stuff. Kind of make me lean toward the Transfer case. The transfer case has never been apart in 350,000 miles. The transmission as any 2.8 owner would know has been apart a half dozen times. Wach-u-tink?
Eric<><
