Bad Leak At The Rear
Drg racr
Southern Michigan
I got the motor back in my Explorer. I took it for a drive, and noticed a huge puddle when I got back. I thought it was my rear main, but I don't think so now. I pulled the starter today, and the inside of the bellhousing is clean and dry. If it was the rear main, I would think it would be spraying oil all over the flywheel and TC. So, I'm thinking I must have pinched the oil pan gasket somehow. The oil is dripping right down the really long Torx screw at the back of the pan.
Am I going to have to pull the motor to get at the oil pan gasket?
There was a plastic strip that goes into a groove on the rear main cap. I didn't use it, because it looked like the oil pan gasket sealed that up anyway. Could that be my goof? :nopityA:
The plastic strip is a "key" that keeps the seal from walking out of the pan.
Yes, you have to pull the engine to get the pan off.
AD
Oh, gotcha. I pulled the motor back out, and it was the rear main seal. It was pushed right out of the block and rubbing against the flywheel. I don't know how that happened, it was sealed into place pretty well.
I hope to have it back together later today and try it again.
if the seal walks out again, purchase new seal, Felpro upgrade Teflon ring the best
dipple the seal seat in the block and pan with a hard sharp center punch in 3>4 locations around the circumference of the hole surface inside.
or lightly stake the seal in with a center punch on the outside edge of the seal hole in block and rear bearing/seal cap to hold the seal in place
