broncobuckinaround
- Sep 24, 2012
trying to figure it out.
rebuilt 6000+ miles ago. new fuel pumps and filter. no codes that i know of.
i believe the fuel pressure reg has been replaced. its the shinniest part on it. plus no fuel smell or strong taste.
i dont believe the injectors are sticking
o2 sensor has been replaced with a denso direct fit.
mufflers are new.
no fuel leaks, also fixed gas tank vent. it was clogged with crystalized gas and dirt. this is wear it started. evap is hooked up properly. but i have no idea if the o2 is picking up on the rich mixture and leaning it out. plus im having an issue where ill drive for a bit start it and it will die but restarts with no issue. only when i shut it off and start.
mufflers are new.
