bad gas mileage and no power goin up hills
automatik or manual trans ???
to bad . check if you have no engine light and more references please!!!
a good spring cleaning is a must for all the world by some time. while I can not help you if I said not much
.. may be just cleaning sensor ... for example ->> mass airflow sensor whatever
what should i do about it?
From the picture, you drive what I have been driving for the last 100 years, right down to the color and no fog lights, less the supercab.
Take a good look at the MAF.
Good luck
electrical cleaner or rubbing alcohol works also. Then disconnect the battery for 1/2 an hour to reset the computer. It can take a couple warm up cycles for the computer to set the new values. Take it to the part store and see if they will pull the codes for you. You need to reset the computer whenever you clean/change a sensor.
and what should i clean it with cuz i dont have any MAF sensor cleaner?
The best method of cleaning an ancient MAF that I have found is air. Not by compressor though. I am talking air time thrown in a safe direction, keeping the parts you will need for the core charge.
I can recommend the Carquest unit, big box stores have failed me twice.
Good luck
Good luck
yes, THIS IS a good method of air compressor and the rubbing alcohol and so also electrical cleaner
