Unplug the TPS(throttle position sensor) 3 wire connector and see if it starts on its own
All fuel injected engines have a "Clear Flooded Engine" Mode in their computer
Computer sends TPS 5 volts with key on
TPS normally sends back under 1 volt when throttle is closed, and 4.5volts when throttle is Wide Open(WOT)
If engine is at 0 RPMs(off), and TPS is at 4.5-5.0volts(WOT) the computer starts Clear Flooded engine mode, which means it leaves spark on but turns fuel injectors OFF, to.......................clear a flooded engine when you crank it over
If RPMs should go above 400 then computer exits clear flooded engine mode and injectors start working, engine cranking speed is 200rpms
So if TPS was shorted or its wires, so sending 4.5-5.0v to computer with key on................then no injectors when cranking, but injectors would start to work if you used starting fluid, RPMs above 400
Longshot but not a no shot, lol.
I would suspect Fuel pump issue, be its FREE to test TPS
Clear Flooded engine is a good thing to know about for testing other things as well
And I use it every morning to start my high mile 4.0l, I crank it over with gas pedal to the floor for 5+ seconds to get oil circulated, then release gas pedal for startup
