- Mar 12, 2011
- Edinburg, TX
- Manual
- My credo
- Fix it till its broke!
Ok so I got coolant leaking from a weird place and I really need help identifying the part and what needs to be done to fix it.
Here it is behind and under the intake manifold it has vacuum lines running out the top of it and it is leaking from under it. Seems it is sitting on the block from the drivers side.
Here you can see it from the drivers side wheel well. It leaks at the mating surface of whatever this is.
and here I tried taking a pic from the top.
It dumps all the coolant I add immedietly. Really need help with this one I'm stumped. And I need to get it running asap
