snatiep
- May 16, 2010
Hello Everyone,
My '96 Ranger 2.3L had developed a miss, mostly at idle. I'm suspecting an ignition coil.
I tested between the 3 terminals on the connectors and had .5 ohms.
Between the plug towers, 14.38K ohms to 14.94K ohms.
Here's what the Chilton manual says:
"If the resistance for all of the readings was between 6,500-11,500 ohms, the ignition coils are OK. If any of the readings was less than 6,500 ohms or more than 11,500 ohms, replace the corresponding coil pack."
The book says these readings are too high and out of specs. Could that be causing the missing?
***edit*** it's definitely an idle issue. When I leave it in 1st gear and idle up a small hill it starts bucking and missing. On the road cruising it runs fine.
I replaced the intake coil two years ago with a used salvage yard coil because I got a check engine light referring to that coil, and at the same time I replaced the plugs and wires.
Thanks for any help.
Nate
Nate
