JTH1972
So, I've had a problem suddenly pop up over the last few days. I can't tell if it's that the battery won't hold a charge, or if the battery is being drained somehow.
it started a couple of days ago when I went to start it up on Sat, and the battery was dead. i grabbed a quick jump charger and got it started no problem. I ran it into town (15 to 20 km one way) and it sat at my mom's place most of the day. Started it that evening no problem and came home. Next day I test start it (later in the evening) and the same problem happened. Jump boost it and started OK. I left it knowing I was just going to have to jump it again in the morning. Jumped it this morning and brought the jump pack with me just in case (good thing!). Truck sat around most of the day and I had to jump it again to get home.
I checked the battery when I got home and it was only reading 12.3V. I boosted the truck to get it running and it was reading around 14.5. Since running it wasn't seeming to get the battery charged, i turned it off and stuck a charger on it for a while. After a short period of time (one charger claimed the battery was charged?), i took the charger off and the battery was reading around 13.4V. I left the truck alone for a couple of hours (no charger hooked up) and checked the battery again, and it's reading 12.6.
Battery is just under two years old. Is the battery pooched or is there something that could be draining the battery? Bad voltage regulator? How do i test the voltage regulator? I couldn't find anything in my manual.
Thanks.
Thanks.
