- Feb 20, 2025
- Age
- 35
- Spokane,WA
- 4.0L
- Automatic
Let me Further Explain my Issue ......
my ABS & Brake light would turn on randomly and i noticed that fuse #20 was blowing so i replaced it and it would randomly blow again, it doesn't do it all the time and the lights would go away once i replaced the fuse but would blow the fuse random again.
since this is the same fuse for my Turn Signals, i put in a Auto Resetting Fuse that Resets after being popped until i was able to track down the Issue since i was running low on fuses.
after i did this i didn't see those lights on my dash again, i assume it wasn't even Popping the fuse since i couldn't see the lights for 30 seconds at least when it supposed to wait to reset, so i assume Problem Solved ?
Well, One Day my Backup camera wouldn't turn and, so i checked the fuse OFC it was still OK but my Reverse lights do not work Anymore, I can turn my Camera on manually by my Radio. Brake Lights and my Front / Rear Park Lamps Work.
Before this i had an assumption my ABS Sensors or Module was going out
or something with ABS ?
so i First Tried to Replace the DTRS Since the ABS, Turn signals, Shift interlock and Brake light Switch is Still Working with that Fuse i put in, So I Replaced it and Still No Rear lights.
Yes OFC i checked my Back Lights, Lights are Good and no 12V at Connector in Reverse.
The Only Other Components i think that might be causing it are the Transmission OSS, Rear ABS Wheel Speed Sensor, ABS Module, Shift Interlock Solenoid (Still Works), Transmission column OD Switch (Still Works), Speed Control Module or Cruise control module (Self Diag Confirmed it Works) and The Turn Signal / Flasher (Still Works).
I Plan on Replacing the transmission OSS, Rear ABS Wheel Speed Sensor and the Shift Interlock Next.
After that, i am Stumped.
Any Ideas What might have Happened and what i should look into next ?
