LITTLE FOOT
how would a stock y pipe right to 3ft 3'' tail pipe (no cat)affect gas mileage and power, do to very little backpressure?
Lower velocity causing reversion. And your idea sounds like shit, literally. And it performs even worse.how so increase bp?
How does backpressure help idle?????????+1 id run 2 1/4 all the way out over the axle, it acts like a jet syphon and helps pull exhaust out, install a muffler or pact of some sort to slow it down to create some backpressure to help idle, but still allow full flow when 30% or more throttle is applied. its been proven over and over again that all an exhaust does on these trks is noise however.
so what about a header? along with small diameter pipe all the way back to a glass pack? on a 2.3?
Rurouni20, please take this as constructive criticism, not flaming you. I don't know where you get your information, but a lot of the information you pass along is incorrect, including the above, and your comments on the workings of ignition systems. I don't want to sound like an ass, but I would think you would want to be correct in what you say as there are many on here who are here to learn. A quick web search will give you a thousand threads on backpressure.your engine has no pressure on it to help keep the fuel in the cylinders while idling, a lil pressure keeps it where its at and keeps your idle speed up a hair as well. while idling the engine is still trying to overcome the load of the alternator water pump etc and is fighting those things, keeping a hair amount of pressure will help stabilize the idle and keep it where it should be. (so you dont lope miss and die, either idling or bumping the throttle to take off.)
