b4000 rear winch
badmts
Lakewood Wa.
i have a 94 b400 and want to put in a rear winch -any ideas or pics?
bolt or weld in a winch channel behind your spare tire & either install a roller fair lead or a sythetic Harse to the rear bumper where the license plate is. If you use a roller fairlead you can get clips that you can attach your license plate to that will allow the clips to snap onto the roller fairlead
how do you want it mounted permanent or or removable if you go the removable route you can get a winch basket with a receiver mount and hook it in your trailer hitch so if you get a front mount you can run it up there or just weld in a permanent bracket for it
I want a permnant mount and I like the idea about the rearr plate too!
The license plate kit can be seen if you click on the TRS Fab & Off Road tab,then click on the Exterior Parts & Accessories tab
ok both winches and bumpers will be in by wed the first:yahoo: and I will post lots of cool pics then we are off to the bedliner place to have most of exterior coated-it will be locked (both lock rights) 4.56 gears,12k frt winch ,8k rear winch,cool bumpers and coated all over!:icon_hornsup:
here it is
