Range98
Any tuners you would recommend? I finally got my heads finished last night, gotta spray them and it's time to put everything back together
That's what I did for my swap in my Trac. I had intentions of swapping in a 1356, but I found out its wider than the 4406/4407 and too wide for my frame. So I put the 4404 (awd case) back in with just the rear shaft. The problem with the 4404 is when you are parked. Make sure to set your ebrake as the truck will roll when parked on any type of incline. Every 04 case I've seen so far slips, and I've had three in 2 different trucks...
SVT
