Cobra5150
First the basics: 1986 B2
Power to injectors
30 PSI at fuel rail
Both fuel pumps running
Removed tank and cleaned 2-3 gallons of fuel
It will run if you spray starter fluid into intake. I got a noid light from Autozone but the one for Ford will not fit, if any other light plugs into the socket should it light? If the noids aren't lighting does that mean ECM?
I'm trying to get the B2 going this weekend as I have a few days off to sort out other issues before I rip out the drivetrain and drop in a 4.0 or 5.0
Power to injectors
30 PSI at fuel rail
