B2 Tail Light Disassembly
Steeda04SVT
U.S. Military - Active
Clovis, NM/Cannon AFB, NM
Has anybody taken their tail lights apart? If so what process did you use to not break them. Thinking about doing a custom mod with some LED's from Superbrightleds.com. Thanks again for any info.
Turn the oven on to 250 degrees let it preheat, toss the lights in for 15 minutes check um make sure they aren't getting too soft, then check them in 5 to 10 minutes intervals until you can pop the reflector off the housing. When you get what you want done get some silicon lay a good bead down Anthe groove and put them back together, wrap them in rubberbands, zip ties or tape to keep them nice and tight and let dry for 24 hours before installing them.
