B2 runs like crap
adsm08
Senior Master Grease Monkey
Ford Technician
Dillsburg PA
31X10.50X15
So my Bronco II has really been running poorly lately and been getting progressively worse. It's gotten to the point where I have to let it sit and run and get warm in the mornings before I can even drive it. Even when I do let it warm up it has a rolling and intermittent low power issue.
I did all the usual, diag, checked fuel pressures, checked spark, etc. Fuel pressure was running a hair on the low side and bled off really fast, so I was gearing up to replace the whole fuel system thinking it was a pressure and priming issue.
Then I decided to do a tune up first. Frankly I find it atrocious that I have owned it for a year and haven't done the plugs and wires yet anyway. Did bank 2 yesterday and didn't see anything super disturbing aside from the Autolite double platinum plugs.
Did bank 1 today (I've been fighting with some unplesant weather) and found this in cylinder 1:
(Yes, that is Harry Kim, no I didn't find him in cylinder 1)
Runs like a dream immediately after sitting for about 36 hours now.
The absolute ONLY way to get it right is to evac the system, pull a vacuum on it, and then charge it from empty.
there!
there!
Yeah, I'm not nearly as worried about the fact that the A/C doesn't work.
that proves it...i'm psychot.....pyschic...plug weighs about 30 lbs....huh?
No, the plug is a little on the light side actually.
I can respect that.....
