B2 auto to man pedal swap?
horsedrivin
Can the auto pedal be removed and the man brake and clutch be swapped in or the bracket need changed
Yes, and the steering column and dash insert. My B2 was an auto on the column and you can't tell because i swapped it all over.
auto to man pedals
didnt know there was an auto on the column ,,,what about the slave setup?is that easy ? how does the brake pedal shaft come out to put the brake /clutch ?
It is much easier to completely swap the auto brake pedal assembly for a manual brake/clutch pedal assembly. I did it in my old '86 BII. It took me a whole 20 minutes.
