jg09
I've got a couple questions about putting my Explorer's engine into the B2. Since I'd ultimately like to do the swap and spend as little money as possible ($0 is a good figure for this project), Can I use the 2.8 flywheel? if i do that, what starter should i use? the 2.8 or the 4.0?
Also, the B2 has an electric fan with a toggle switch in the cab. I'm having a brain fart right now, but as I recall, the Explorer has a mechanical fan. Is there anything special that i need to do to remove the Explorer's fan? can I just remove the fan clutch and call it good?
