B1095 abs code
RavoHimself
RBV's on Boost
enfield, ct
Anybody have any experience with this code? Can't seem to find much about about it. What I did find either said faulty wheel speed sensor or the hydraulic abs pump. Either way my abs light is on, brakes work great just no abs
Your 2003 Ranger has 4 wheel ABS?
P codes are engine, transmission and emission, "Powertrain" related
B codes are climate control, cab electrics, seat belt, and airbag related, "Body" codes
C codes are ABS, suspension, steering, "Chassis" related
I can't find a B1095 code listed
But since you have an ABS light on then could be C1095-ABS Hydraulic Pump Motor Circuit Failure
Which could just be a loose wire on the Electronic Brake Control Module(EBCM).
And braking should work fine, this is only used for ABS, hard stops, so not a safety concern unless you need it :)
I honestly would rather not have abs anyway. I learned to drive without it. I'll get around to figuring it out. Just too cold to worry about it
