GingerKid
I the process of swapping a wheel joint in my ranger, I am now missing a slinger. This happened because instead of swapping the joint on the shaft that was already in the truck, I pulled another shaft from my parts explorer and swapped a new joint in there to reduce the time my truck was down. The problem is, I didn't notice that shaft didn't have a slinger on it until I put everything back together and the front end was making noise.
Now my Haynes manual says I can just tap the slinger off with a hammer. I tried using a rubber mallet and just ended up bending it a little bit. Is there another way to get this thing off with out bending it beyond using?
