Axles
Fraser1989
I am just about to pull the trigger on a new axle and I just want to make sure they will fit.
Will all 8.8 ranger axles fit my 1996 4.0 ext cab xlt regardless if they come for a 3.0, 4.0 or any ranger newer than 1996. The one I am looking at is a 2004 B4000 axle with a 4.10 LSD.
Just want to make sure it will fit.
http://www.therangerstation.com/forums/search.php
Be sure you start there. Assuming that you did search and did not find it..............
Yes it will bolt up just fine. Now is your truck a 4x4? If so you need to make sure the gear ratio's are the same.
Any Ranger 8.8" '93-'09 is an exact fit for your '96.
