Axle Swap Question
naw, it will not make it a full time 4x4........4x4 all the time is bad unless it is an AWD and made for it. This is to get rid of the retard vacuum hubs that rangers came with because when you wheel with them it has a tendancy to blow apart and then you are stuck with no 4wd. what happens if you put em in is you put it in 4x4 in the cab and then have to get out and lock the hubs manually. it is a pain once in awhile but it will save you the problems of vacuum hubs.
