DLABdan
I'm pretty sure this is somewhere else but honestly I'm too lazy and don't have the time to look.
So heres the story. My truck (2005 Edge) has been pulling hard right for a while. I put it on the alignment rack at work and it shows the RR toed in and the LR toed out. The measurements also confirm that the distance between FR and RR is shorter than FL and RL. (I will put a picture up later after work). I've been told that the locating pin could be broken or the hole in the pad on the axle could've been made bigger. Has anybody else had this problem or know of any fixes?
It also might be good to note that I took her to hell and back multiple times for the first 3 years I owned her.
Thanks a lot for all the help.
