Axle Pivot Bushing too loose in bracket?
Maui-sprint
Oahu, Hawaii
I just performed a 4" lift on a '91 Extended Cab with a D28 re-using older skyjacker-style pivot brackets I pulled from a junkyard rig about 10 years ago. I replaced the axle pivot bushings with new parts. Im at the point where I have everything together and am ready to tighten the axle pivot bolts with the weight of vehicle on them. However, after installing the axles I'm left with a gap between the axle pivot bushing and the mounting flanges on the bracket. This doesn't seem normal to me. I believe that the bushing should fit nice and tight within the bracket. Should I just torque it up and attempt to pinch the bushing? Or should I install some spacers between the bushing and bracket flanges on one, or both sides?
That bracket looks like it might be bent a little, and is why it's wider... You can certainly tighten that up and be done with it.
Is the other side the same way?
Yeah, what they said, drive it home... if the cast side is that loose I would be more worried... speaking of the cast side is the lift you got one that has a drop plate for the stock passenger side pivot bracket or a whole different bracket that just bolts to the engine crossmember? If it's the drop plate style I would clearance the furthest bolt hole closest to the diff, those are known to punch holes in the differential on Dana 35's
Just to verify, you should have a Dana 35 axle on a '91 (I don't remember from a couple years ago...) which is the spindles I have for you... not that it matters which axle it is in this context but just checking... 10 bolts holding the front diff on is D35 and 12 is D28
I wonder if there is a difference in the thickness of the D28 vs D35 bushing? Would be the first time I've heard of it...
D28, D35 bushings are the same width (I think same bushing even).
×2, all '91, '92 trucks came with the D35, regardless of engine (it wasn't until '93 we started seeing the D28/35 hybrid weirdness, which also carried the 10 bolts on the front)
