Axle Code?
cowtownkid
Aledo Texas
Hello All,
I recently pulled the bed off of my Ranger to install a new fuel pump. While doing this I decided to change the gear oil...Very easy with the bed removed. After the oil change I wondered what axle I have. I read the "code" info on the drivers door & It gives the axle as #92. I consulted my Haynes Manual and found no axle code info. I then pull out the Owners Manual & the codes run up to a # 91...Which is a convential 3.27. There is no code # 92 in my manual. I have a 1993 2WD 4.0 Auto, Supercab.
I did write down the Tag numbers on the differential while changing the oil and it reads...S352A 308 88 3H25. I am assuming with this code I have a 8.8in 3.08 gear ratio? Can anyone confirm my assumption especially since my code on the door is not listed in the Owners Manual?
Thanks In Advance
cowtownkid
according to the tech library you are correct. 8.8, 3.08, open.
