axle code questions
Diesel_brad
Gilbert PA
I am in need of some info on my 04 ranger. My rear axle tag has 4L10. but my front axle sticker says 3L54.
My axle code on the door says R7.
O and i run 2500RPM at 70MPH. O and 265 tires
And the 4wd works fine so what ever gears are in it they are the same front to back
If the axle code is right you have a limited slip 8.8 with 4.10 ratio
