axle code help
mkpecor
black diamond W.A.
i have a 88 ext..cab rang w/ a 2.9 the raear axle reads sl 7375 that would mean 3.73 gears with a 7.5 ring gear right? the front reads 3.73 but why doesent the back say 3.73. any info on this.:temper:
It most likely does, the 3 is probably buried in dirt or is under the bolt head.
i took the tag off and cleaned it, i dont know if the factory messed up,the tag is not bent or nothing its perfect,
