Asagarner22
I have a 03 edge 4.0 with a 8.8 rear end 4.10 gears would the axel shaft from a 07 ranger 7.5 rear work in my 8.8 I've read it should bit I want to be sure thanks in advance #rangernation
As long as the wheel base and transmission are the same, it should. I would strongly recommend comparing it to what you have now before you buy. The old one has to come off anyway.
I was tboned and impact bent my axle just slightly but I'd rather change it now then deal with worn tire or it damaging axle itselfIt looks to me he just wants to change out a rear shaft, not the whole axle. (guessing worn wheel bearing journal or bent flange).
7.5" and 8.8" axle shafts will interchange, as long as the criteria I mentioned above is met.
Lmao no one cares about your grammatical correction*Axle.
You obviously have too much time on your hands
Thanks for your time appreciate it alotThey should be the same, regardless of wheelbase and transmission.
What is important is that you're on the same side of the '92-'93 width changeover date ('93+ being wider), and that it's for the correct side (left or right).
A '07 shaft should fit a '03 no problem (as long as neither are an FX4 model with the Torsen 8.8" axle).
Welcome to TRS.
not true. some enjoy it, but i need it. lol he does it to keep confusion at bay ...Lmao no one cares about your grammatical correction
