the complete quote is:
Please note on a 1995-up the Clutch master mounts to the pedal
bracket, NOT the firewall.
Is anyone still wondering why?
AD
if the Clutch master cylinder is not mounted TO the sheet metal the sheet metal isn't stressed.
the 1995-up master cylinders mount to the pedal support bracket
the bracket is mounted to the dash, firewall & cowl in an interlocking
support structure.
The master cylinder passes through a grommet in the firewall that
only serves to keep the weather out.
The firewall on the 1995-up RBV's isn't stressed in an isolated spot, so it doesn't crack.
Gen1's, Gen2's and early Gen3's do.
Whoever designed that specific area of the original rangers
should have their engineering degree shoved halfway up
their a$$ and the half not inside them should be set on fire
and be allowed to burn out.
If the reinforcement was on the INSIDE of the firewall the
firewall wouldn't crack.
Funny I have no degree, but when I design and build something
it doesn't break.
Engineers are always looking for the lighter, minimum material (cheaper)
solution, in this case the royal f-up was simply putting the material
they did use in the WRONG place.
They could have skipped the reinforcement entirely and the
resulting structure would be NEARLY as good as it is.
Hell, a fender washer on the inside held on with a nut would
prevent the damned thing from breaking
Something I strongly recommend for everyone who still has
an unbroken firewall.
There is more than enough extra bolt sticking through the firewall
to put a washer and a nut on the bolts that hold the clutch master
cylinder to the firewall.
what would be a step better would be to use a 1994-94 Master cylinder mounting cup as a template for the holes and use a piece of 1/8" thick
steel on the INSIDE of the firewall, even if only held in place with nuts
on the slave cylinder mounting bolts.
Then there's the overkill solution that I outlined above.
Sandwich the firewall in two pieces of steel spanning past
the entire area.
Though admittedly this would work better on an unbroken
firewall the level of the reinforcement makes the presence
of the original firewall less than relevant.
My original post wasn't about looking for suggestions.
I don't have an engineering degree, but when it comes to mechanical engineering, I can do excellent and even elegant all by myself.
this topic is less abut solutions
Mainly I wanted to make everyone aware of a serious problem
that COULD be lurking only a few inches from their left foot
waiting to bite them on the ass some fine morning....
so everyone with a 1982-1/2 to 1994 RBV
put a floor mat on the ground, get down on
your knees and take a good long look up under your dashboard.
you may find nothing... but then again...
"Out of sight" is "out of mind"
but in this case the map has one of those old labels that
says "Here there be Dragons!"
AD
