AledoGYoung
- Apr 29, 2013
Has anybody replaced the automatic four wheel drive control module in their bronco ii?
1988 = module in dash (1989/1990 = in panel behind seat)
With just the pigtail connector connected (other two disconnected), you should get a click, and several flashes of the red LED light (four I think) if the module self-tests OK. If it lights up solid, then test failed (that, or you didn't unhook the proper connectors).
Dunno how reliable the test is, but as said, failed controllers are very rare (49 out of 50 times it's the shift motor or it's sensor, or the little stopper bushing around the screw on the internal gear has disintegrated).
I did the control test and I got a constant red light??
My moms 88 BII had a bad controller, throw us for a loop too because the self tested ok, but after hours of testing everything, cleaned the shifter motor and the brushes. ended up getting a yard controller and everything worked.
Thy sure can but lots of fun troubleshoot.
Cleaning the transfer case motor
Transfercase troubleshooting
