auto trans switch to a standard?
roughranger
ok i have a 85 bronco II 4x4 that is automatic with overdrive (a4ld?). i want to swap a standard shift trans into mine. i have a 84 bronco II 4x4 with a standard trans in it. how hard is it to swap over? its a rough truck so i can do some mods...... it looks like the hole is there for the clutch mastercylinder with the hydraulic reservoir holes recessed. how hard is the third pedal going to be to put it? it looks like a rod and pin but not sure. how do you do the shifter for the stick in the auto body as well? both trucks have 2.8's in them but will the standard trans bolt to my transfer case? thanks in advance for any and all help
You get a peddle set from a manual change the whole set.You need a reservoir A line master cyl,slave cyl I wound up buying both of these because donors didn't work maybe you'll have more luck.I understand the FM 145 is a different length the M50D is the same length as the a4ld so that might mean drive line length problems.As for the transfer case it will fit any combination.
