auto to stick
Rulebreaker
Solid Axle Swap
Manton,MI
I got my clutch master cylinder, line, reservoir, and slave today and i'm not sure how to clock the master in the clutch bracket as I thought the reservoir line would be on top but the hose dont seam to lay out that way. Also where does the reservoir get located?
The Gen 3 master resi barb is pointed to the driver side if I remember right. The older ones are vertical.
Sent from my DROID RAZR using Tapatalk 2
master cylinder gets mounted to the black plate on the firewall where you can get access to wiper transmission. you will see 2 dimples in the steel that's where the reservoir mounts. now the master cylinder line runs behind inner fender well on the outside of the frame then bends up over top of the frame (plastic line should have a u shape in it that's where it goes over the frame) and sits near where the frame meets the underside of the truck and it should pretty much be right there to connect into the slave cylinder. I just did a whole m5od swap on my truck so it is fresh in my mind. if still confused let me know
Haha thanks man. Got tired of the auto
