Auto to standard transmission
kanetuck
I just swaped the auto for a standard but know the starter will not ingauge.Do i need to hook up the wires on the right side and to what do i hook them to?Is there a neutrial switch if so how do i bypass the little guy?
The wires on the right side of what??? Also, is that right as in direction or right as in correct?
Your post is kinda vague and since we can't check the truck out for ourselves the more details you can give us, the more help we can give you.
i was told that the auto trans and manual trans use diffrent starters. did you get a starter for a manual trans?
Not on the 1st gens. The 2.9 uses a 8 2/3" fly wheel and flex plate.
The 4.0 kept the 8 2/3 flex plates for the autos but jumped to a 10" flywheel for the manuals.
