Auto Hubs - thrust spacers?
65Ford
Connecticut
Wheel bearings seemed bad so I broke everything down and find out there are no Thrust Spacers on either side. Left out from a previous brake/bearing job? Does anyone know the actual specs of the spacers? OD, ID, Thickness. Thanks for help.
Ur best bet is to junk the auto hubs and go manual its like 250 for everything needed and that new out of box. its the best upgrade I ever did on my truck no more hopping 4wd will work
If he's talking the splined thrust washers that go over the end of the axle shaft, you still need those whether you have auto or manual hubs.
Those washers are probably gonna be dealer or junkyard-only items (though I think I've seen reports LMC Truck has them also).
Not the splined washer(axel shaft spacer)....looking for the specs on the two thrust washers between the cam assembly and the wheel bearing adjusting nut. Called everywhere locally, dealer only. Junkyards wont break up good hub. Don't want to switch to manual, probably gunna sell it. Just want to rebuild it right. If I can get specs can have buddy at machine shop cut them.
