auotmatic hubnuts
feellnfroggy
Knoxville, TN
what size is the freakin socket?! none of the parts stores around here know, and everything posted in the tech library is for the manual locknuts.
Shouldn't be tight enough that it makes buying a socket necessary.
channel lock size. you should not need much torque at all
It's this size:
6" adjustable much too small... channel lock pliers are much easier to find... all you need are the channel lock pliers and a strong magnet to get them off
Ok so I'm pissed I looked evrywhere tghen I found out o reillys has it. Plus found out its same as 35 mm which I bought to do another car 2 weeks ago and left it with a friend. All good though thabks guys.
