Audio Controls and Apps Center
Ranger 20
Austin
Having an issue with the heads up display that controls audio and apps. Some times it shuts down and the randomly restarts.
This has happen twice over the last 6 months
Has any one had this issue? if so what was the fix?
Perhaps they pushed updates...
I does seem that it would happen on power up though.
You may have a loose connection?
Check to see if your issue matches anything described in this TSB, if so go make the dealer fix it. :icon_thumby:
I looked on my ford login page.
They had a up dates for SYNC. .
I taking it in to have them do it with a wild change.
Thanks for the lead
I've had mine lockup/restart probably a dozen or so times. there's a simple reset procedure
Press and Hold Power and Right Track Select Buttons
61263
Haven't had it happen since I got the Sync 3.4 update, but I also haven't driven much since then either
