Affirm.....When you run out of money..... LOL
This.Yes, repair cost IS ALWAYS a factor
But its not related vehicle value, UNLESS you are building strictly for re-sale, a restoration or a flip
If you are building/repairing a driver for you or your family then it should be looked at differently
If you invest $4,000 into a driver and you think you can get another 5 years without other major repairs then that will cost you $67/month over 5 years to drive it
It would be hard to find a used car for $67/month, and you wouldn't know its history
Yeah, that...
My '90 has worn me out several times, but I'm deep enough in it now that I just can't give up on the thing... It sat for a few months lately because the parking brake pedal was stuck down, fixed that in about 30 minutes the other night and the shoes aren't adjusted enough to even grab so I called it done for now... that and all the oil leaks even after I've put a lot of effort into fixing them in the last couple years, gave up on those for now...
I for real gave up on my '94 Geo Tracker, it's a blast to drive, decent gas mileage, but it's high mileage and parts are getting HARD to find. Not to mention I've rebuilt the transmission twice (bearings just can't take commuting duty) and the engine almost twice... It's been sitting for 3 years now, I moved it to the driveway from the side yard a year ago, put a new head on it and now it needs fuel injectors and a battery... I'm stubborn and will fix it before I sell it since it will double the selling price and is only $300 in parts... but the motivation isn't there, it's literally in my way and I just don't wanna... Once I get my shop done I'll get on it, I could use the couple grand to build the office in there...
I gave up on the Ranger when the cost of repairs was more than the value of the truck. The transmission lost ALL of it's fluid in a less than 30 mile drive, the fuel pump was near shot, and the left rear wheel cylinder was leaking. Oh, and the power steering pump had a leak. Total cost of repairs would have been over $4,000.00. Value of the truck was less than $1,000.
My '95 Taurus needs a water pump, a rad, likely the parking brake cable (not sure why the left rear brake is dragging (discs), and probably front end work. It's driveable for now, I just won't take it on the highway until I get that left rear brake seen to.
Also depends where you're at in life, if your working on a "project" then I assume you already have a good daily driver so the project is soley for enjoyment not practicality. In that case yea it's gone the second I'm bored with it or can no longer find any fun in working on it.
It's different for your daily driver. When I was dirt poor with just one vehicle there was no giving up on it, it had to work no matter what. Couldn't afford to buy anything else and couldn't afford to let it die. Now that I'm not AS dirt poor I look at my daily drivers from a strictly momentary standpoint. If it's cheaper to replace it with something else more reliable then it either just goes into the project category or gets sold and I'll buy a new car/truck.
I doubt I'll ever get rid of my ranger but I know at some point it will definitely be replaced as my daily driver.
Everyone is different on where that threshold is. Once it becomes a chore with no seeming end in sight, that's pretty much when you are at a decision point on whether to continue or just throw in the towel. Like Dirtman said, if it's your primary mode of transportation and money is an issue, then it might change things. Only you can decide that. Can you afford to just stop and get rid of it?
I've hit that point a couple times on my trailer rebuild/modification. Repetitive work for hours at a time for weeks at a time can just plain beat me down but progress is getting made and what I'm doing, no one else makes. If they made it, the price would be insane. Trailers half the size of what I have are about $7,000. When it's all said and done, I'll probably have about that in my trailer but it will have more utility, twice the size, and it will be exactly what I want.
depends on the vehicle. whats the history with it? inherited, you got laid in it for the first time (or some other memorable moments in it...
Also depends on the issues. like Dirtman said, when it isn't your daily driver and it stops being fun to work on, maybe time to let go. if there is no real sentimental value in it, scrap it, or turn it into the parts donor for the next project. severe frame rust would be something I would think about ditching, also if it is just sitting taking up shop or yard space and you want to do other projects...
as for spending a ton of money on it, I think I would look at it as a "is this going to be fun to drive when done and I will get enjoyment out of it?" if yes, i would spend more money on it. I probably put close to 2k in repairs in my 97 over the last two years. some of that was needed maintenance (which I don't count toward it being a money pit, you need to replace tires/ shocks/ brakes as they wear...) and the truck is probably worth 3500 here. I would go and spend another 2k on it as I had time to work on it (not my daily driver) and as I am able to do so.
AJ
But its not related to vehicle value, UNLESS you are building strictly for re-sale, a restoration or a flip
This.
if you own the car outright, then even a couple thousand in non maintenance/ wear item repair can be worth the money, especially if it is a decent car and there is only one or maybe two systems that need the extensive repair. if it needs extensive repair in more than 2 major systems (engine, transmission, body/ frame, electrical) it may be money ahead to spend several thousand on a downpayment or outright buy a different vehicle...
AJ
Keep a vehicle long enough, and it's guaranteed that maintenance will exceed value. But "maintenance" is everything - wipers, bulbs, oil changes, and so forth. We don't think for a minute about those, but somehow the big-ticket items (even if they can be spread over the remaining life of the vehicle) somehow get our attention, more. New set of tires on a 10 year old truck? Ouch, but ya gotta do it. Rebuild the tranny? Time to cry in your beer, even if the tranny will outlive several sets of tires, and cost less in the end.
Something to think about.
