bikerboy117
- Jun 27, 2013
About a month ago, the dash on my Ranger started acting up. While driving, all gauges would go dead except for the fuel gauge, the Check Engine light would come on and the digital odometer would be a series of dashes instead of numbers. After a few minutes, the instruments would come back, then go off again. The truck would still run without any problems.
When I went to the parts store to check it out, they said they could not find any fault codes with the reader despite the light being on. When I tried to restart the truck, nothing happened. The starter would not engage, the anti-theft light was flashing and the odometer was all dashes.
I had the vehicle towed to the Ford place. The said that the PCM unit was bad and needed to be replaced. The fixed it and the truck ran fine for a couple of weeks until the gauges started doing the same thing again. Sure enough, now it wont start.
Now, I have a hard time believing that my truck went through TWO PCMs in less than a month. And the fact that the gauges come on and off intermittently suggests theres a loose connection or loose ground somewhere. But for the life of me, I cannot figure out where. Im thinking in the starter relay circuit
Can anybody point me in the right direction?
My truck is an 07 Ranger, 2.3L 4-Cyl 5-Speed Manual. Its a base model without power windows or locks.
