and I'm about to go on a week long vacation 500 miles from home.
Same story as usual, idle miss, runs smoother under a load/higher rpm. Smells like its running rich, plugs come out white (lean?), good cranking compression (180-185lbs all cylinders), etc etc
Heres the thing though...its slowly starting to get worse. Used to be the same no matter what temp it was at, but now it runs best cold, and starts missing more as it warms up. Stumbles occasionally if it sits for a minute, but not always, and the newest development is an occasional stumble while accelerating...but rarely.
Good example was just a little bit ago. Was on my way home from work, just got up to the speed limit after stopping at an intersection, then out of nowhere the engine stumbled, bad. Felt the truck vibrate and drag a bit as the motor was stumbling, kinda felt like it just quit firing altogether for a second
I've checked for vac leaks, good fuel pressure, O2 sensors read properly, etc.
I'd appreciate any other ideas anyone has, I'm completely lost!
