ASL Light Flashing
kdowney50
I just rebuilt the rear brakes on my '94 B2300. Now the ABS light flashes all the time. Anyone else have this problem?
Found the problem! Turns out the dash lights were out as well. Apparently, the ABS system is powered from the same fuse. I replaced the fuse and the ABS light quit flashing. I have dash lights too!
The problem returned a few days later. After taking apart the rear brake lights I found an intermittent ground on one of the brake light wires. Every time it would short to ground, and I stepped on the brakes, a fuse would pop and the dash lights, brake and tail light, and the front running lights would go out. I taped up the bare wire and solved the problem.
