- Aug 6, 2007
- Age
- 43
- Iowa
- Automatic
You also have more offset than you did with the stock wheels. I think 4x4RangerGuy eluded to that with the stock ones it is a no go.
The offset remained the same, hence the 5 inch BS. The stock wheels are a 16x7, to keep the same offset (and to make the bearings and other front end parts happy), you need a 5 inch BS on a 16x8 wheel. The stock wheels are, IIRC, a +12mm offset, which is what my new wheels are. With the 265/75/16s, minimum width should be 7 inches. If you go to 33s, you're probably gonna need a wider rim.
krugford how wide are those tires on your truck
It moved the sidewalls inboard and outboard about a half an inch. The wheels are flush with the outside of the fender flares. IMO, it turned out just right. I'm extremely happy with the fit/look
