AOD to c6
88mudder
waterford michigan
im totally sick of AOD tran's..im ready to swap in a C6. Do c6's use a TV kickdown like the AOD does? Also, will i have to modify my driveshaft length? I have 4x4 and will be using a 4x4 trans.
The c6 has a detent (passing gear). It does not have to be adjusted perfectly or even hooked up. If it is adjusted to tight it won't shift into 3rd. To loose and it won't kick down. If you put in a c6 you'll want the roller kit installed. If you can build the trans yourself you can get the parts from an E4OD. Even if the E4OD is bad the rollers will probably be ok, just clean 'em good. If you have the trans built at a shop it may be difficult to get this done unless it is a perfomance shop.
In '89 the c6s got the rollers from the factory. It is hard to find a small block bolt pattern, '89 and newer c6 though.
The AOD housing is about 1/4" longer but, the adapters are different and I don't have them here to measure.
id really like to run the c6. Is there a way to make them fully manual? I really like the feeling of having to shift it manually.
