Anyone wired up a line out converter before?
Musick17
Lincoln, IL
Here's what I have going on. I am putting a 10" sub in my girlfriends 2005 ford focus. I've hooded up several sets of subs, but never with a stock head unit. So I bought a line out converter.
I have the remote wire run from behind the dash to the amp and its hooked to the "remote" port. I have the power cable from my battery positive ran to the amp. I have a ground ran from the amp bolted to a metal bracket in the trunk (I sanded it down to bare metal). I have my RCA cables from the line out converter to the amp. I have the sub hooked to the amp.
I have one sub and a mono amplifier. The converter has 4 speaker wires on it. I have one set of them hooked to the drivers side rear speaker.
The amp light turns on when I turn the car on.
Should my ground have a voltage reading?
Do I only have to hook the line out converter to one speaker or is it mandatory that I hook it to two speakers?
What all connections should have a voltage reading when the car is on?
Thanks guys
Converter is a transformer, it converts higher Speaker level voltage to lower Line Level voltage.
If hooked to one speaker then you will get the frequencies and "level" for that speaker at the Sub.
Now in general a stereo recording will have low frequencies on both channels, Left and Right, but that is just in general, having both left and right connected takes the "in general" out, you would get all low frequencies at the sub, so up to you really.
Obviously the Rear speaker wire the sub is connected to needs to be getting a signal, so fader would control sub volume along with Main volume control.
If sub light is on then you have power at the sub
A Ground is 0 volts
Battery is 12 volts
Neither is "power"
Power comes when a higher voltage is connected to a lower voltage.
12v----------sub
Sub won't work this way because there is no lower voltage.
12v-----------sub---------0v(ground)
Sub light comes on(and amp) because power is passing thru it to 0v
Metal on a car doesn't always mean ground(0v), engine and trans sit on rubber mounts to isolate them from frame and body, body sits on rubber washers to isolate it from frame, body parts are also painted BEFORE they are assembled, so bolting them together doesn't automatically give them a good ground, no bare metal, which is good because there is less rust, lol.
But if the sub light comes on you do have a 12v and a 0v connection
