Anyone on here rebuild an FM146?
kodogtwh
RBV's on Boost
ASE Certified Tech
North Carolina
2.9 V6
There are pretty obvious big snychros, and little synchros. They are easy to replace. I'm mainly having issues determining which spot the one 'thick" synchronizer ring goes. I didn't pay attention while disassembling, that's my own fault. I ended up using all the small synchronizers and reusing an old one for 5th & rev because the 'thick' one made the gear stack too long to install the retention ball & sleeve on the end of the main shaft. After all was said and done i realized: "That's stupid, i'm stupid, there's somewhere that the 'thick' ring goes, and i need to disassemble this thing again and find it."
So i've come here for answers. It's not specified in the rebuild kit or the service manual.
Addendum: I broke a chunk off the transmission case with my little 1/4in impact, thus rendering the entire transmission as scrap. Now i'm in need of a good condition used FM 146.
I'm guessing it's the reverse synchro or 1st? Is it missing teeth in several spots around the edge (reverse?) The 1st gear one pictured below looks thicker, not missing teeth. I don't remember, I should, I built a couple of these recently.
My book shows MIT-14H for reverse
MIT-14A for 5th
MIT-14B for 2nd
MIT-14C for 1st
MIT-14A for 3rd and 4th (above)
MIT-14A for 5th
MIT-14B for 2nd
MIT-14C for 1st
You got any for sale? 😅 I ended up Totalling out mine by breaking off the boss for the 3-4 detent ball plug.
Oh dang… you broke that off the main case? I don’t think I have that… maybe you could get tig welded back together?
I'm not gonna put my welder friend through the trouble of gluing some dirty, cast aluminum back together, over a transmission that's not worth that much. And I mean whole transmissions. I'm sick of the crap m5od I put in. Shifter keeps popping out of the gates leaving it stuck in random gears at times. Shifter bushings don't help.
Just a dumb question…. Why not use a better trans? Something like the M5OD?
Ive had all 3 of the most common 4x4 transmissions. 145, 146, and currently have an m5od. The Mitsubishi transmissions are lighter, shift better (IMO) and are no weaker than the Mazda. Plus I have an '87, which has a different floor, causing me to have to chop it up to get the m5od to fit. Not to mention how it's pretty easy to break aluminum shift forks.
