anyone know these engine dimensions?
cody93
Duluth GA
Google has not been helpful.. Anyone happen to know how long the motors on the list are? From the back of the block to the water pump pully? Mabey some of you have one of these motors at your disposal and could measure one up. I'll get the Lima length myself tomorow and add it to the list.
1: 2.0/2.3/2.5 Lima I4 - 25 inches
2: 200/250 Falcon I6
3 240/300 Truck Six I6
4: 255 Chysler Slant6 \6
5: 289/302/351 SBF/Windsor V8 - 29 inches.
6: 4.0 Jeep I6
7: 258 AMC I6
8: 351/400 Cleveland/335 series - 29 inches
My 302 with the long water pump (say late 80's Crown Vic) is about 29-3/8" to the nubbin on the end of the water pump. The water pump pulley sits behind that.
There are a couple different water pump setups out there for at least the 302 so there won't be "this is how long a 302 is" measurement. I am not really that familiar with the other engines to know if they vary too.
There is a '76 400 on a stand at work, I can try to remember to measure it if you want.
Edit: I found this in the V8 swap forum.
Engine Family
Width Length Height Weight
221/260/289/255/302 24" 29" 27.5" 460lbs
Boss 302 24.5" 29" 28.5" 500lbs
351 Windsor 25" 29" 29" 525lbs
351 Cleveland 25.5" 29.25" 29" 550lbs
351M/400 26" 29.5" 29" 575lbs
332-428 FE 27" 32" 29" 625lbs
427 SOHC 32" 34" 30" 680lbs
429/460 "385 series" 27" 34" 29" 720lbs
Boss 429 30" 34" 30" 635lbs
4.6L SOHC 29" 26.9" 28.6" 600lbs
4.6L DOHC 28.9" 27.1" 29.6" 576lbs
http://www.therangerstation.com/forums/showthread.php?t=242
awsome, thanks for the measurements, now the v8s on the list are covered, time to do inlines.
