anyone have a tranmission wireing chart for a
pittman4
a 87 ford bronco 2 2.9 5 speed trans (standard)? any help would be great on what plugs go where on the transmission just purchased it and it didn't have a trans in it
thanks
The plugs are specific to where they go. You shouldn't have any problems putting the wires where they need to be, unless youare putting a different trans in.
ok their are alot of loose plugs that are not pluged in and they go nowhere so i just wanted to see if anyone had a chart
There should only be 2 plugs that go into the transmission. One for the backup light and one for the neutral sense switch.
i have one thats on the side and a plug with wires on top and one plug on the drivers side of the trans
1 plug on top, one on the passenger side and there will be one on top drivers side of the transfer case.
thats guys but to let you all know their are 2 different plugs that will go into the side of the trans one will let you put the truck in gear the other will not after cranking
If it's a stick NONE of the sensors will prevent it from going into gear running or not.
